Cabin air inlet screens on front of car.
Has anyone replaced or removed the cabin air inlets grillwork on the front of their car? Looks to have 3 small nuts holding the ductwork on inside the wheel well. Looking to replace the grillwork with a larger mesh to allow more airflow. Does anyone have a photo available of original grillwork under the duct available? I would guess the mesh is just glued on but need to know and if the mesh is flat or bent when installed.
Thanks, Blas |
It's bent and glued.
If you want to replace it just buy a piece of mesh and cut it larger than the opening. Then fold the sides back and glue to the inside of the body. At least that's what I did to replace mine. |
I found some nice SS mesh. But it is interlocked wire. So I need to be careful when I cut it and if I need to bend it. It will come apart I think. Thanks.
| All times are GMT -7. The time now is 09:27 AM. |
