November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree1Likes
  • 1 Post By keezling
Old 09-30-2015, 09:00 PM
Default Cookie Tray
Figured if a Cobra can have a turkey pan, then why not a cookie tray. Made this to mount under the air cleaner assembly. Will line the outside with foam to seal it to the hoodscoop. Did it on my 69 Mach and it was worth .5 second in the Qtr mile. Will make a pass and post the result.
Old 09-30-2015, 09:06 PM
Pic of pan under air cleaner.
Old 09-30-2015, 09:15 PM
Ready to test in a couple of weeks.
Old 10-01-2015, 10:59 AM
That is EXCELLENT! My hat is off ou you sir! That probably works BETTER than a TP...
I was/am pondering making a turkey pan out of, well a turkey pan that can be had on ebay for $20-$40...
Vintage LG Miracle Maid Gem Coat Aluminum Turkey Roaster Roasting Pan | eBay
Superformance 1764
Built 427W
Aiken SC USA
Old 10-01-2015, 11:26 AM
Tim7139's Avatar
Cobra Make, Engine: Superformance #2660, FE-406
Uh, would'nt it make sense to remove the foam in the front, so the air can get in???
The older I get, the faster I was.
Old 10-01-2015, 01:02 PM
Remove the foam? Really? Foam seals below the front opening, fully enclosing the hood scoop making it functional.
Old 10-01-2015, 01:32 PM
Tim7139's Avatar
Ah, pic is a little deceptive, looked lke it went into the bulge. I'm with you.
Old 10-01-2015, 04:43 PM
DWRAT's Avatar
LOL,
That would have been funny but a bit to obvious.
Nice job to get a true cold air intake.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 10-02-2015, 05:42 AM
Cobra Make, Engine: CR Cobra 3169
Would it be a problem if it rains?
JD
Old 10-02-2015, 10:43 AM
Cobra Make, Engine: FFR fat block tko 600 9"
If you used a real turkey pan off e bay assuming it is used, would it smell like Thanksgiving when the engine got hot?
DWRAT likes this.
