-   Superformance (http://www.clubcobra.com/forums/superformance/)
-   -   SPF steering wheel.. (http://www.clubcobra.com/forums/superformance/83062-spf-steering-wheel.html)
tjl3 10-16-2007 12:54 PM
Anyone had their steering wheel off?? Need to straighten my steering wheel as it has always been a tad crooked from day 1.... Don't want to booger it up so am looking for suggestions...does the steering wheel cap pop off or screw off?? I would assume it pops off as the diamond needs to be straight with the wheel also...
Thanks in advance...
Tom
Velox 10-16-2007 01:31 PM
The cap just pops off - held in by a close fit and a rubber 0-ring - no rotation required :3DSMILE: :3DSMILE:
Mister 10-16-2007 01:39 PM
A credit card does a great job popping the emblem off.
Mike
Bill Wells 10-16-2007 02:22 PM
yep, credit card or a plastic throw away knife will work too . Bill
Madmiles442 10-16-2007 07:31 PM
Really easy to get the wheel off. After the cap's off, you'll see the nut. Loosen away. The wheel's on a grooved rod, just pull it off and over one groove.
I lined mine straight up-and-down and marked it with a Sharpie before removing it so I'd know where I started.
tjl3 10-16-2007 09:57 PM
Thanks to all!! Figured it was something like that just knew the answer was among the masses!! Thanks again!!
Tom
SantaFe66 10-17-2007 09:50 PM
You could also have an alignment shop put it up on the rack and have them adjust the tie rod ends to align the steering wheel to straight. Saves boogering up the screw heads on your wheel.
Paul
