-   Superformance (http://www.clubcobra.com/forums/superformance/)
-   -   Hook spanner for coil over adjustment (http://www.clubcobra.com/forums/superformance/85758-hook-spanner-coil-over-adjustment.html)
ztarum 03-04-2008 10:07 AM
I have a newer SPF with the Bilstein shocks. I would like to adjust the ride height. I measured the nuts, and they appear to be between the common 75mm and 80mm hook spanner sized. Which size do I need, or do I have to buy the wrench that the SPF dealers sell?
PS - I know the hinge type hook spanner will work, but I really don't like them and would rather have the non-hinged type.
JCoop 03-04-2008 02:41 PM
I think this is what you need:
QA1 T120W - QA1 Coil-Over Shock Adjusting Tools - JEGS
http://www.jegs.com/images/photos/100/122/122-T120W.gif
RedBarchetta 03-04-2008 03:38 PM
What...You afraid of expanding your vocabulary while laying on your back under the car?!? :LOL:
-Dean #747
scootter 03-04-2008 03:57 PM
You will be changing the geometry of your suspension once you change the ride height. You should get the alignment check after changing the ride height.
I have never used one of those wrenches. I like the using the good vocabulary while laying on the cold cement.
Scott
JCoop 03-05-2008 07:32 AM
-Dean #747
:LOL::LOL::LOL: Unfortunately, the spit that shoots UP with a spirited and prolonged use of the F word makes it a messy proposition.:LOL::LOL::LOL:
Seagull81 03-05-2008 03:58 PM
Ztarum,
You don't have to have the special wrench. I used a punch from my punch set. You could also use a drill bit, but I would use a glove if I did that.
Steve
