Wheels on old SPF work on new SPF
Would a set of pin drive wheels from an older SPF, say 0867, fit onto a newer one, say in the 2100's?
I'm looking at the wheel only, not the bolt-on pin drive hub. Thanks! |
yes someone chime in here, some one has got to know this....
i also need to know this. |
http://www.clubcobra.com/forums/show...ghlight=wheels |
I had an early one and a late one at the same time. They will interchange.
It's the spinners that are the problem.
Trigo spinners can be used on WAW2 but not WAW1 wheels. WAW1 and WAW2 spinners can not be interchanged, and neither can be used on Trigos wheels. Note the angle, length and the taper of the bearing surfaces are not the same...I posted a photo in my gallery of the spinners side by side. Please note the differences and make your own decision. When the new owners manual is released, ther is a HUGE section on the various wheels for SPF's. BTW: I have no idea when it will be available. And it's not from me... Just a heads-Up... |
So my set of PSE wheels that fit on 0867 should fit on 2100 if 2100 uses it's same hub and spinner, just change out the wheels, right?
I mean, that's how I changed these onto 0867. Just unspun the originals, mounted wheel, spun original spinner back on. They pulled up snug, balanced fine, never got loose. |
| All times are GMT -7. The time now is 06:35 AM. |
