Aluminum calipers
Does anyone know of an OEM aluminum caliper with parking brake? Has anyone used an electric E brake caliper?
There is a floating caliper which is steel but comes with a cable operated parking function. It does not weigh much more than a caliper wo the ebrake. GM
4-piston main calipers. Electronic parking brake.
https://www.wilwood.com/Images/Brake...6142-DR-sm.jpg https://www.wilwood.com/BrakeKits/Br...o=140-16142-DR Wilwood also has mechanical parking brakes: https://www.wilwood.com/Calipers/Cal...4%20Mechanical |
Those Camaros are what Iam looking for but the pistons are too small. Thanks
Speedmaster has an aluminum caliper setup with integral parking brake. Single 1.75" piston. Fits 11" rotors (not included). Fits Ford 9" rear end with "small ends" (Torino). I have no idea whether that's what you have, but you should be able to figure it out with a few measurements.
https://www.speedmaster79.com/BRAKE-CALIPERS https://product-arena.s3.us-west-1.a...CE521.1021.JPG Speedmaster also offers a "Ford Late Model Large & Small Bearing 4 Piston 12" Rear Brake Kit". Aluminum calipers and mechanical drum parking brakes. Drilled and slotted rotors. https://www.speedmaster79.com/Ford-L...Rear-Brake-Kit https://d2c5keh8asbas7.cloudfront.ne...CE164.1015.jpg |
| All times are GMT -7. The time now is 09:26 PM. |
