Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-04-2003, 09:01 AM
JOHNNYCOBRA's Avatar
Cobra Make, Engine: 1984 S-V WITH A 5Liter Eight stack EFI
Unhappy Cleaveland heads
Anybody know if I can re-use my cleaveland four-tube headers
if I switch to a 351 windsor?
Will redrilling the attach bolt holes do it ?
Or are the Winsor exhaust ports located in a different place?
Any help would be appreciated!
Thanks
Old 08-04-2003, 11:44 AM
The windsor and cleveland heads have identical port spacing. But the port shape and exhaust flange (head) angle is different, so the collector will not be located in the same location. Your signature says you're running a cleavor--a W block with C heads. Again, due the difference in deck height, the collector will not be in the same location when you finish.
Mike
Old 08-14-2003, 07:26 AM
Bonos's Avatar
Club Cobra Member
Cobra Make, Engine: 1967 E-M with 302 Ford
Cleveland heads ports are oval/round shaped and larger than the square smaller Windsor type heads
Old 08-14-2003, 07:54 AM
kountzecobra's Avatar
Why would anyone switch from a Cleveland to a Windsor?
David Shelton
Lone Star Gashole!
Old 08-14-2003, 08:05 AM
rdorman's Avatar
Renegade Nuns on Wheels
Default Second the motion!
Why would you switch?
Rick
OhioCobraClub.com
LondonCobraShow.com
Old 08-14-2003, 03:58 PM
Default Why switch?
I'm switching engines from the cleavor (windsor/cleavland)
to a straight windsor, and I wanted to use the existing exhaust
assy.
I want to use a new windsor stroker block (SVO) with some
aluminum heads.
The old engine is going into my sons 1969 Mercury cyclone
But....
if I cant get the existing headers to work I'll just have to buy new ones.
JG
Old 09-08-2003, 08:02 PM
Cobra Make, Engine: Unique FIA
Tell your son he is out of luck and keep the Cleveland. Save the windsor for when you need a good boat anchor
All my ex's live in Texas
Old 10-09-2003, 06:39 AM
750hp's Avatar
Them's fightin' words, Steve !!!
An SVO stroker windsor with alum heads should give all but the most expensive FE a run for it's money.....
Craig
HTML code is On
