What is the Correct 427 FE SO Radiator Cap?
What is the correct radiator cap for a 427FE SO?
AMK Products makes two versions. One that says S.M.C.O. 14# and another that says Autolite 13#. http://amkproducts.com/radiator_caps.asp Shin |
Zinc plated S.M.C.O.
the higher pressure rating is also desirable Bud:JEKYLHYDE :JEKYLHYDE :JEKYLHYDE |
Autolite 13#, the expansion tanks can't take much more pressure than that (13 lbs). If not running the old style expansion tank you can go up with a higher rated cap.
Thank you Bud Man and Eliminator. I am running the original tank and the cap I am replacing is 13# but just generic so I want one that is more authentic. I guess that will be the Autolite.
Shin |
| All times are GMT -7. The time now is 02:20 AM. |
