-   Tech Tips (http://www.clubcobra.com/forums/tech-tips/)
-   -   main jet extensions and pv modification (http://www.clubcobra.com/forums/tech-tips/98382-main-jet-extensions-pv-modification.html)
vector1 07-18-2009 09:19 AM
i'm looking into doing the aforementioned modifications to a bg carburetor and and found this thread below which has the pv mod and wondering if anybody has done this and their experience.
http://www.clubcobra.com/forums/show...ighlight=stanj
regarding the jet extensions is there any need to go to a larger size once the extensions are installed in your experience?
don't suggest to remove the secondary pv cause it 's not going to happen since i have a 1-1 linkage.
thanks
i did email stan about his carburetors, i don't think i can afford the $2400 right now, but it would be nice i'm sure.
vector1 07-23-2009 02:26 PM
well i wasn't gettin any relief so here is what i did
http://www.clubcobra.com/photopost/d...ion_Small_.jpg
vector1 07-23-2009 02:31 PM
the pv cap is a 3/8" hard copper cap, the tubing is brass 5/16".
when the tubing is cut the crimped portion is captured between the jet and the metering block, make to any length and crimp if preferred.
the cap is simply press fit into the block, might have to jb weld it later but didn't know if this is going to work yet.
total cost--less then $5.
