Tech Tips
http://www.clubcobra.com/forums/tech-tips/)
| Sinjin |
09-10-2009 12:37 AM |
Free Play in Jaguar positrak (3.31) Diff
I have had my Jag positrak diff fully rebuilt by Jag mechanic but I'm concerned about the amount of free play. What degree of movement should I expect when rotating the rear 17 inch rim.
| Mike Bontoft |
09-10-2009 10:07 PM |
When you are rotating the wheel you are picking up backlash and also clearance on the diff output spline plus posi gear clearance. About 3/8" at the circumference of the tire would not be unusual.
Mike Bontoft
cwiinc.com
| Excaliber |
09-10-2009 11:36 PM |
That freeplay is also the primary reason you should never "dump the clutch". Best to let it out until you feel everything get tightened up, all that slop is taken up. Hold the clutch right on that "edge" and when the light turns green, GO! That avoids the hammer impact to the gear sets which leads to all kinds of broken stuff.
| Sinjin |
09-13-2009 07:47 PM |
Thanks guys
From what you say the "free play" I have is probably normal
| Danr55 |
09-22-2009 06:17 PM |
If you don't like it, I have a 3.54 Posilok differential I want to sell.
| All times are GMT -7. The time now is 10:42 PM. |
