Go Back   Club Cobra > Club Cobra Tech Areas > Tires and Wheels
December 2025
Old 12-23-2010, 10:12 PM
fordracing65's Avatar
Default goodyear stock car special
has anyone ever used the goodyear stock car specials on ther cobras. they have the yellow writing on the sidewall instead of the white, are they good for racing, compred to the avons and bb's, i know they are slicks and bias ply but there cheaper than most tires and have a very high speed rating just curious
PRIDEnJOY
Old 12-24-2010, 06:40 AM
lamaluv's Avatar
I have used them on my car for the track only. They give great traction but take some getting use to compared to BFG T/A's or TOYO's. They don't wear very good as they are soft and very stickey. There are several others on here that have used them a lot more than I have that will probably chime in soon.
Dick
Old 12-24-2010, 08:44 AM
thanks, cool pics those are the tires i was talking about, anyone else please chime in
PRIDEnJOY
Old 12-24-2010, 09:42 AM
SSSammy's Avatar
Default Track only ...
These are pure slicks, although Roger Krause will hand cut a tread pattern if you wish. When new, they stick like glue (and throw stones) until they reach the limit, then they break loose suddenly. This is what slicks do, so maybe you are ok with that. I just discarded mine after three years, they got hard.
Better all around tire of this type is the Sports Car Special (the venerable "Billboard") - still not DOT, but a good all around tire for street or track. Made on the same carcass, but with tread. Very forgiving at the limit, you can tell when they are about to go. Depends on your level ...
Sam
Old 12-24-2010, 10:46 AM
Are these the ones that Nascar uses? If they are, I thought that Nascar uses radial tires now and have for quite a few years. At least they have said so (I think at least, guess I could be having a brain fart). They would be great for the track but they would sure wear out fast on the street.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
Old 12-24-2010, 12:01 PM
SSSammy's Avatar
Originally Posted by tcrist View Post
Are these the ones that Nascar uses? ... They would be great for the track but they would sure wear out fast on the street.
No. These are vintage replicas, like our cars. They are bias ply, subject to flat spotting when cold and not DOT rated, like most radials. Goodyear makes them on an occasional basis, so they are not always available. But the look is period correct I get about 5K miles out of a set of Billboards, with a mix of track and street. You'd get maybe 300-400 miles of pure track.
Sam
Old 12-24-2010, 02:31 PM
jdean's Avatar
I thinks these are what Clois runs. If so he has a lot of track time on them. Hopefully he will see the post and comment.
6th generation Texan....
Old 12-24-2010, 03:46 PM
thanks for the advice all you guys are great , you really know your stuff
PRIDEnJOY
Old 12-24-2010, 03:51 PM
i was also wondering could i use these on the drag strip as well, and how would they fair, i have a dragstrip and raodcourse near by and want to use same tire on each tarmac
PRIDEnJOY
Old 12-24-2010, 06:17 PM
Rick Parker's Avatar
I think Clois has used them too, he is an avid track participant and should have a lot of feed back.
Rick
Old 12-24-2010, 08:29 PM
Mac VABCH's Avatar
Cobra Make, Engine: BDR #250
I use these tire strictly for the track. They can generate a enormous amount of grip compared to a DOT tire. I switch to the vintage sports car special slicks from a Nitto DOT tire and the grip level difference is astounding! As for wear I have 8 track days on them with little wear. They are subject to flat spotting and after extended sitting they are not exactly round until they get some heat in them. Just for that reason alone I wouldn't us them on the street. Very difficult to get enough heat in them for a smooth ride. Mac
Old 12-24-2010, 11:57 PM
Cobra Make, Engine: csx4163 full comp alu. body
Put a set on Halibrand mag wheels and they went flat real quick. Left front went flat in about 10 days. I called Finishline motorsports, said they had epoxyed the wheels to stop porosity. Went to local tire shop just to see for myself. Air was coming thru the sidewalls. Put a set of Avons on the mag wheels and no more leaks. Tires and wheels set in rack until I want to change the looks of the car. Have been setting in rack for 6 months pressure was down 2-3 lbs. Mag wheels were not the problem. Put the Goodyear slicks on another set of wheels and will air up as need be. I have Trigo wheels with billboards on car most of time. Goodyear Billboards will lose about 3 to 5 lbs in 6 months.
Old 12-25-2010, 04:15 AM
Not that great on the drag strip. Even with a good burnout, they won't warm up enough to provide the GREAT traction they are capable of. It takes a full lap on a road course to get them hot enough to really work well. I've had the rear end wash out on me a few times on that "first lap" before the tires warmed up. You do have to be careful until then.
Even cold they do MUCH better than any typical street tire, I'm just saying they do WAY better when you get 'em hot.
Old 12-25-2010, 11:11 AM
thanks excaliber good info
PRIDEnJOY
Old 01-11-2011, 02:16 PM
Larry N Johnson's Avatar
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
Great open track tires!
