Valve stems
http://www.clubcobra.com/forums/tires-wheels/117560-valve-stems.html)
| fordracing65 |
10-06-2012 07:36 AM |
Valve stems
Metal vs rubber valve stems, which do you recommend and why, thanks for any info...
| rodneym |
10-06-2012 09:43 AM |
I don't think the 'advantage' of metal stems can be realized in our cars (high psi). Plus on Trigos, which I assume will be on your Kirkham, have the stems in the spokes, so it's plenty safe.
Just my 2 cents.
| fordracing65 |
10-06-2012 09:53 AM |
Thanks for the response, my car just arrived and I noticed rubber stems istead of metal, and I was just wondering when I have to replace the tires if it's worth it at that time to switch to metal...
| Gaz64 |
10-06-2012 01:52 PM |
Depends on who fits them. I had a metal stem come loose and leak. I've also had a rubber stem fracture and a quick deflating tyre was the result.
Comes down to personal choice.
If had metal again, I would be supervising the valve stem fitment.
| fordracing65 |
10-06-2012 02:17 PM |
After doing some research I heard metal leak and rubber wear out, go figure..
| All times are GMT -7. The time now is 04:03 PM. |
