-   Transmission Talk (http://www.clubcobra.com/forums/transmission-talk/)
-   -   Husrt Comp/Plus shifter ID? (http://www.clubcobra.com/forums/transmission-talk/123788-husrt-comp-plus-shifter-id.html)
crenbbf 11-23-2013 05:40 AM
Hi All
Could anyone help with the ID of this shifter.
It was purchased under the assumption it was for a 'stang.
It is to be bolted to a Toploader
http://i1276.photobucket.com/albums/...psa51affa9.jpg
cheers
Rick Parker 11-23-2013 02:03 PM
The shifter mechanism is the same regarless of application, the mounting plate allowed for the location of the shift lever itself. Usually the lever came directly out of the mechanism and if required had a bend in it to move it to the left closer to the driver. The shift rods can be replicated or purchased. Here is an example of an OEM Ford shift mechanism on a T-10.
[IMG]http://www.clubcobra.com/photopost/d...re_220__2_.jpg[/IMG]
crenbbf 11-25-2013 10:48 AM
Thanks Rick
Must have been a tricky one though only one response:LOL:
cheers
bill37341 11-25-2013 01:18 PM
There is a 4 digit # on the mechanism. (Facing to the bottom in your picture). This will help identify it's original application. Should be something like 8327. It will be just above the slot for the bottom shield. Bill.
crenbbf 11-25-2013 10:38 PM
Thanks Bill
Now ID'd and thankfully the right one
cheers
