Old 11-29-2013, 06:45 AM
Cobra Make, Engine: Unique 427 S/C, FE 440, top-loader, 3.31
Default Toploader + Gear Vendors overdrive?
Has anyone done this? Does the Gear Vendors replace the tailshafthousing? Does it increase the overall length of the trans? Can it be installed in a short driveshaft Cobra?
Old 11-29-2013, 06:52 AM
Gear Vendors under/overdrive auxiliary transmissions, Ford 2-Wheel Drive 4, 5 and 6 Speed Manual Transmissions.
Old 11-29-2013, 09:55 AM
CHANMADD's Avatar
Mine is a 4 speed jaguar Moss box with Laycock overdrive unit.......it fits fine ....the driveshqft is about 12 inches.......2000rpm at about.80............2.88 rear and 26 inch dia tires::.....I believe Laycock sold to these guys
Old 11-29-2013, 11:45 AM
I dont think it would fit. If it might fit, how long would your driveshaft be and how short is too short? Do you have an IRS?
" It ain't no big deal"
Old 11-29-2013, 12:41 PM
Yes I have IRS. Drive shaft around 12 -14 inches. Can not tell from website how much length is added to trans.
Old 11-29-2013, 01:42 PM
Why pay that much for an overdrive unit when you can buy a new TKO for. $2300?
Old 11-29-2013, 05:42 PM
CHANMADD's Avatar
I agree ...just get a five speed........
Old 11-30-2013, 05:07 AM
Default adds 7" to length of trans
760010M-27 : Ford Range Torque Spliter Overdrive 27% with a 5.125 retainer index | Advance Adapters
Old 01-14-2014, 10:12 PM
If you are running a close ratio toploader, you can switch to a wide ratio, and change your rear gears to 2.88's, and you'll have the same overall first gear ratio, now with an "overdrive" like top gear.
Old 01-14-2014, 10:28 PM
Karl Bebout's Avatar
The torque splitter sounds fine, for lower power cars <400 '#s of torque.
Karlos
