Like Tree10Likes
  • 1 Post By eschaider
  • 1 Post By KarlzEE Bebout
  • 2 Post By eschaider
  • 1 Post By undy
  • 2 Post By KarlzEE Bebout
  • 1 Post By sunman
Old 08-10-2023, 03:19 PM
Daytona Dek's Avatar
Cobra Make, Engine: Shell Valley Daytona, Ford 302
Default Ford 9 inch rear axle oil.
My Daytona with a 9 inch rear axle (not limited slip diff) might have a noisy axle. I say might because the car is very noisy anyway and because the rear end is very rigid with rose jointed suspension I’m thinking resonance might be an explanation. So you might be asking why I’m bothered? Well I’m not too bothered, ear plugs might be a solution, but thought if I filled the axle with oil that is most likely to quiet it then that’s the best I can do then put up with it. If I’m not mistaken and I stand to be corrected standard oil is EP90. An oil specialist here in the U.K. can offer a dual EP 70w/140 or a straight EP140. Thoughts please? Thanks.
Dek
Old 08-10-2023, 05:43 PM
eschaider's Avatar
If you are running a cruising or highway ratio like 2.92, 3.08 up to 3.55, the EP90 will work fine for you. If you have a 3.73 or deeper R&P, say, 3.90, 4.56, or?, then you will benefit from the EP140 lubes
Most 9” Ford pumpkins normally run whisper-quiet if they are set up properly. If they are not, no amount of lube is going to fix the problem. Pumpkins have specific fluid levels necessary for proper lubrication and cooling. Exceeding those design specs will typically not do anything good for you. If you have sufficiently overfilled the pumpkin, then normal operation will cause the oil to foam and usually come out of the breather.
If the noise is coming from the ring and pinion, then it is time for a new R&P. If it is coming from a wheel bearing, then it is time for a new wheel bearing. If it is coming from a damaged spline in its corresponding side gear, then it is time for a new axle and, most likely, a new side gear.
cycleguy55 likes this.
Last edited by eschaider; 08-13-2023 at 04:32 PM.. Reason: Typed EP70 and should have typed EP90
Old 08-13-2023, 02:27 PM
Thanks for your reply Ed and sorry for the delay in responding. Did it earlier then got a text and when I got back it had disappeared into the ether. Firstly I must ask what a pumpkin is? I think this might be a case of two nations separated by a common language?
From what you say a different grade of oil won’t make the diff quieter. I’m pretty sure it’s not a wheel bearing noise or spline. I thought a higher viscosity oil whilst obviously not curing a wear problem might alleviate the noise from it. As far as use is concerned here in the U.K. on congested pot hold roads any “cruising” is only achieved on motorways in the early hours of the morning with the risk of speeding fines from overhead gantry cameras. Ggrrhh!
Dek
Old 08-13-2023, 02:44 PM
Forgot to address the ratio. I’ve got no idea quite frankly. Anyone know if there is identification stamped on the casing and where to look? I know it can be worked out on the car but this is way beyond my pay grade. It’s got a Tremec 5 speed and has fairly long legs. About 35mph per 1000rpm in top gear.
Dek
Old 08-13-2023, 04:08 PM
Dek, it's unlikely that your differential will have a gear ration identification. Raise your rear end after blocking the front tires. Put the transmission in neutral. Make a mark on the propeller shaft and one on the inside of one of the tires. Count how many times the propeller shaft rotates during one rotation of the tire. The number of shaft rotations will pretty accurately tell you your differential ratio. EEZY PEEZY
If you do find that you need some rebuild/repair work on the differential, that would be a prime time to install some sort of positraction. Years ago I used a "Powertrax" unit that was easy to install (did it myself) and really did the job. It has no clutches so there will sometimes be a click or snap when turning while backing up. Not an issue, just different. The Powertrax was still in the car, 50,000 miles later with no issues. I'd dome lots of drag racing, turning 10.7 seconds in the quarter mile, after driving 75 miles to the track, and then driving home. My 2¢ worth.
Alfa02 likes this.
Old 08-13-2023, 04:35 PM
eschaider's Avatar
Dek
Dek,
Pumpkin is a colloquialism in this country for the removable 9" Ford center section containing the ring gear, pinion gear, and gear carrier. Apologies for the ambiguity; it was not intended.
When the noise comes from the ring and pinion, it is caused by improper installation. No amount or type of lube will silence this. The ring and pinion must be replaced with a known good (usually new) ring and pinion and then properly installed. The noise you are hearing comes from a mechanical interference between the incorrectly installed ring and pinion gears. The mechanical interference physically damages the gears such that they can never be reinstalled to produce a silent running rear axle.
PostScript:
You need one of those new-fangled 100KW radar/camera detectors off the dark web. It scans continuously for a threatening device. When it finds one, it locks onto it and zaps it with a 100KW laser blast reducing the electronics and other stuff to a smoldering pile of rubble before the device can see you!
MaSnaka and Alfa02 like this.
Old 08-13-2023, 08:17 PM
cycleguy55's Avatar
No drag racing here, but also running the Powertrax Grip Pro. I installed it myself as well, without the benefit of a dial indicator. Paid a LOT of attention to backlash and tooth pattern. No problems after 7 years of use so I must have done okay. Highly recommended, IMO.
https://www.powertrax.com/product-in...action-system/
Brian
Old 08-14-2023, 02:53 AM
Thanks KarlzEE for explaining the method for determining the ratio. It’s not difficult but don’t suppose it’s sensitive enough to determine all the ratios outlined in Ed’s reply. Certainly would be able to differentiate between say 3 or 4 though.
Thanks again.
Dek
Old 08-14-2023, 04:53 AM
undy's Avatar
Why guess on what's making the noise? Put the rear axle up on jack stands. Have a friend start the car and put it in gear. Underneath it with a mechanic's stethoscope check the center section, axle bearings, etc.
Sawdust likes this.
Too many toys?? never!
Old 08-14-2023, 07:41 AM
Had thought of this but don’t really fancy the idea of the car on axle stands with someone in it taking it through the gears at different revs with the rear wheels spinning inches from my head! Funny how you get more cautious as you get older. Probably would have had it on bricks when I was younger.
Old 08-14-2023, 08:24 AM
Dek, You'll be able to get pretty close to what the ratio is just by eye-balling the shaft revolutions: 3 1/4=3.23, 3 1/2=3.50, 3 3/4=3.73 etc.
Cycleguy, As I remember, I didn't have to remove the pinion so the lash to the ring gear was not affected. Anyway, it was a darn good unit and the pricing is very reasonable. $350 (=-) at Summit. Hard to beat if you're willing to but up with the clicks. The first time was a bit unnerving.
eschaider and Daytona Dek like this.
Old 08-14-2023, 09:03 AM
sunman's Avatar
This could be any one of the rearends bearings or the gears.
I suggest you pay a mechanic for a diagnosis and repair estimate.
We remove the wheels and listen for noise.
Use a 4-5 foot tube to your ear, don’t climb under.
Daytona Dek likes this.
Old 08-14-2023, 09:47 AM
eschaider's Avatar
Dek,
You might get lucky and find it is some obscure, inexpensive, and easy to correct problem, but then again, it is much more likely that you won't! We don't get the easy or inexpensive solutions falling into our laps very often.
For the noise to be loud enough to be audible over your pipes and then loud enough to become an irritant, there are only two things that can do that. One is a bad carrier (or pinion) bearing, and the other is an improperly installed ring and pinion.
When you disassemble the rear end to remove the ring and pinion, it is a walk in the park to check the bearings. If they pass muster, then it is time for a new ring and pinion. It is really that simple.
All of the, it might be this, or it might be that BS, is a form of intellectual problem obfuscation. You attempt to convince yourself it is not as bad as you know it really is. Don't waste your time on the mental masturbation; fix the problem. After all, that was the original reason you embarked on this journey of pain and suffering.
This one has no easy or cheap way out other than do nothing and tolerate the noise until something breaks.
Morris and Daytona Dek like this.
Old 08-14-2023, 10:17 AM
sunman's Avatar
It could be a bad U-joint or axel bearing.
Ring gear to pinion play check by feeling it by hand.
Old 08-14-2023, 01:53 PM
MaSnaka's Avatar
I replaced my 9" rear with a unit built and supplied by Currie 3.73. It made a howling noise when in between accelerating and decelerating, kinda like coasting. I did put a heavier oil in it and it helped a lot. Years later I went to a 3.50 ratio and the mechanic shop who specializes in rear ends used Richmond gears and said they Richmond used to be noisy but now they are quiet. I dont hear that howling anymore so assuming Currie sets up their center sections correctly, I believe some gear manufacturers make better quality or maybe tend to have a quieter mesh.
Old 08-14-2023, 03:10 PM
Originally Posted by eschaider View Post
Dek,
Ed you hit so many nails on the head there. Mental masturbation-I can’t get that phrase out of my head now!
Dek
Old 08-14-2023, 03:17 PM
Yes the noise is a bit like that. Present on the over run. Interesting that the heavier oil helped which is where my post started. Thanks John.
Dek
Old 12-20-2024, 01:56 AM
If you're experiencing noise from your 9-inch rear axle, it could be caused by worn bearings or resonance from the rigid suspension. Using EP90 gear oil is standard for most 9-inch axles and should provide adequate lubrication for the bearings. Thicker oils like EP70/140 or EP140 may help reduce noise by damping vibrations, but they can increase drag and heat, potentially affecting ball bearing performance. If the noise persists after switching oils, consider checking or replacing the bearings, as worn bearings may contribute to the noise.
Old 12-20-2024, 04:25 AM
Originally Posted by likorplf View Post
If you're experiencing noise from your 9-inch rear axle, it could be caused by worn bearings or resonance from the rigid suspension. Using EP90 gear oil is standard for most 9-inch axles and should provide adequate lubrication for the bearings. Thicker oils like EP70/140 or EP140 may help reduce noise by damping vibrations, but they can increase drag and heat, potentially affecting bearing performance. If the noise persists after switching oils, consider checking or replacing the bearings, as worn bearings may contribute to the noise.
Thanks for that. I didn’t know either of those things. That thicker oils can affect bearing performance or that thicker oil can dampen vibrations from stiff suspension.
As an aside I’ve got a shush shush noise on the over run in certain gears on my roadster which I’ve put down to harmonic resonance through the anti-role bar. One of the cures for that is to fill the role bar with expanding foam apparently but I haven’t got round to that to see if it works. I have got a roll bar in the Daytona which could also be bringing resonance into the cockpit.
Old 12-20-2024, 05:41 AM
ERA174's Avatar
Cobra Make, Engine: ERA 427, 482ci sideoiler
An easy way to gauge the health of your rear differential is to draw a sample of the lube and have it analyzed. Draw the sample after taking the vehicle for a ride to warm up the lube and suspend any contamination for sampling. I don’t know who in the UK performs this service, a Google search should reveal companies who perform this service in your area. I use Blackstone-labs.com here in the USA, the cost is approximately $30usd. If the lube in your differential has not seen sufficient use, analysis may not reveal a problem, even though you may have one. If the lube has been in use for at least a few thousand miles, the lube will probably be contaminated with the remnants of any components wearing excessively. If with sufficient use the sample doesn’t show any contamination to indicate a problem, don’t worry, you’re probably good to motor on.
