-   Transmission Talk (http://www.clubcobra.com/forums/transmission-talk/)
-   -   Ford Windsor bellhousing question (http://www.clubcobra.com/forums/transmission-talk/39735-ford-windsor-bellhousing-question.html)
ian 03-20-2003 09:02 AM
Can anybody tell me please if the bellhousing from a Ford 302w (manual gearbox type) will fit a 351w engine. I have been offered an aluminium one. Also, are there any implications on clutch/clutch mechanism that I should be aware of? I thought all Windsor bellhousings were iron! Thanks. Ian.
Mr.Fixit 03-20-2003 09:06 AM
Get an SFI approved scattershield.
Leo 03-20-2003 09:13 AM
Ian,
The bell housing bolt pattern is the same for a 302 or 351W block. Many 5.0 Mustangs (and I'm sure others) had aluminum bellhousings. As most vehicles (especially kits) don't provide much protection a scattershield is usually a good idea for performance applications as even the iron (?) bellhousings are cast.
Bart Carter 03-20-2003 09:34 AM
Option #2, go with the bell housing and use a kevlar blanket for safety.
David Kee 03-20-2003 06:17 PM
The bolt pattern is the same but there were two different flywheel sizes, 157 tooth and 164 tooth. Get the casting numbers and go to http://www.davidkeetoploaders.com/be...ingidchart.htm
ian 03-21-2003 09:09 AM
Thanks everyone for your replies. I'm trying to find out the casting number. Ian.
DaveR 03-21-2003 09:33 AM
How many of you are using a Kevlar Blanket? Where did you buy it? How much did it cost?
Bart Carter 03-21-2003 04:31 PM
Call Levy Racing, 480-446-8442
