SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
December 2025
Old 05-04-2003, 06:22 AM
Send a message via AIM to hdheritage97
Default Tilton Throwout Bearing
I knew that I had a hydraulic bearing in the car but didn't at all understand how it worked or was connected before I tried to remove my trans to change my clutch. Unfortunately, I think I now fully understand that the unit is CONNECTED to the trans...lol. It appears that the "bearing" part of the unit has come free from the main unit but for now I stopped the disassembly till I can get some further ideas from you guys. I guess my main concern at this point is to get the trans out, I have to disconnect my lines, which will mean I have to re-bleed. Has anyone found a good way to do this ?????? I spoke with Tilton and they seemed to indicate that I would have to bleed the system when it was fully installed, through the inspection port, and to me at least, that seems damn near impossible. Does anyone have any encouraging ideas that will make sleep possible again ???? I was thinking of hardlining a bleed line down to the bottom near the inspection port, what do you guys think ?
Thanks,
Cliff
" Like my Grandfather always told me, if you are truly good at something there's no need to brag, others will be sure to do that for you "
Old 05-21-2003, 11:23 AM
XXQQQME's Avatar
Cobra Make, Engine: West Coast, Ford 460
I believe that there are two ports on the throw-out bearing. One inlet and one outlet. It doesn't matter which is which. One is connected to the slave cylinder operated by the clutch pedal and the other is used to bleed the system. On mine, I've tie wrapped the two lines out of the way so the clutch does not rub against them (could cause clutch to fail). On the end of one of the braided lines I've installed a bleeder valve. It will take two people to bleed the system. . . one to depress the pedal and one to open and close the valve. I usually pump up the system with the pedal and then open the valve and catch the fluid in a jar or can. I do this 3 times.
Good Luck!!
'bacher
Old 05-21-2003, 11:54 AM
Clois Harlan's Avatar
I have had too much experience at this. Here are some of my notes:
Successfully Bleeding Hyd T/O BRG
Clois
"Let's roll"
"Be part of Something Good
Old 05-21-2003, 12:30 PM
The outlet valve should be on the top of the bearing so you don't get any trapped air in the system. Just like on brake calipers - keep the bleeder valve as close to the top as possible.
Your tilton instructions (if you have them) should give you a tolerance range for the closeness of the actual bearing face (which hits the pressure plate fingers) to the pressure plate fingers and you'll need to probably remove and install the tranny several times to get this setting as close as possible. Depending, of course, on what kind of room you have under the car - which likely isn't much. Sometimes a small mirror and good flashlight can assist in seeing what you need to see through an opening in the scattershield/bell housing.
Have the new clutch and pressure plate in and buttoned down secure and properly aligned so the tranny will slip in and out easily. Then in and out with the tranny, checking each time how close the t.o. bearing face is to the pressure plate fingers. Use a mirror and flashlight to do this or also put markings on the hub (stationary part) of the t. o. bearing to use as a reference point while testing the actual bearing for travel. You'll need someone to push the pedal carefully while you are under the car checking the t.o. bearing movement.
You may have to actually pull at least one of the lines (inlet perhaps) off of the stationary part of the t. o. bearing so you can adjust it, depending on the style of t.o. bearing you have.
I just spent several days doing this in a friends Cobra - 427 so, with toploader and his t.o. bearing assembly was a "screw on" style that has a locking shoulder bolt to keep the mechanism from moving. This type of t.o. bearing has to go one full turn at a time in it's setting. So, I had to remove the inlet ss line, turn the stattionary part of the t.o. bearing how ever many turns I thought it needed to be, reinstall the locking shoulder bolt, reattach the inlet line, put the tranny back in and secure it and then have someone push the clutch pedal so I could reflect an image with a small mirror and tell what was happening with the bearing and the clutch fingers.
After doing this multiple times, we finally reached a point where the bearing while disengaged from the fingers was as close to them as it could be (within a turn) without riding on the fingers.
The clutch now works fine.
We also made good and sure that the clutch pedal does not over extend the travel of the t.o. bearing. (you don't want the bearing to be pushed out of the stationary housing that it rides in.) Using an adjustable pedal stop usually takes care of this concern.
If your bearing assembly has adjustment posts (like 4 posts that position the bearing in or out from the tranny) then you may not need to remove the inlet line, since you can do the positioning of the assembly simply by using the adjustment posts (bolts). That would save you some steps from what I had to do. (on the one I just did, the outlet line didn't need to be disconnected since it was not secured to anything on the free end and that allowed it to spin with the bearing mechanism as I screwed the mechanism in or out to adjust it).
It's a pain at first (trust me on that ) but once you have your "system" worked out, it's not too hard to complete.
If you have the screw on t.o. bearing and need any pics, I can send you what I took of the one on the car we just did.
And yes, by all means, make SURE that when you are done and everything is buttoned down, both inlet and outlet lines are well secured AWAY from any moving parts inside the scattershield. A spinning pressure plate will wipe out a ss braided line in less than a block. Also make sure nothing is going to be snagged by any shifter linkage movement or anything else on the exterior of the scattershield.
With either inlet or outlet braided ss line, sometimes just a simple half twist of the line outside of the scattershield can cause it to move in one direction or the other, on the inside of the scattershield. Such movement could easily place it near the spinning internal parts. So after everything is done and secured, double check to make sure those lines are still as clear as they can be from the internal spinning parts.
As far as hard lining either inlet or outlet line? That might work provided you don't have to keep disconnecting them each time you try to move the tranny. Maybe a short hard line leading out of the scattershield that then connected to a flex line - that might be a concept? (would possibly avoid the risk of internal line movement that could hit a spinning component). I might look further into that if I ever do another one.
Good Luck.
