-   Transmission Talk (http://www.clubcobra.com/forums/transmission-talk/)
-   -   Dog ringed? (http://www.clubcobra.com/forums/transmission-talk/44586-dog-ringed.html)
zach 08-21-2003 11:12 AM
Dog ringed?
What is the difference between dog ringed tranny and a synchro tranny? More specifically is it stronger, shift better, hold up longer,etc? Are they that much more noisy? Thanks for the comments.
David Kee 08-24-2003 08:31 AM
A Jerico has dog ring engagement. It is noisy but very easy to shift. I shift mine under full power but it does wear the edge of the engagement teeth. There is a larger air gap between the teeth so it will bang and clank when driving easy. I would not want to drive it on the street but have customers that do.
Most stock street type transmissions are synchronized. This setup is quite reliable and will last for a long time. The synchronizers match gear speed with the output shaft speed when a shift is accomplished to allow a quiet, smooth non destructive gear change.
