Ford 392W, which bell housing/ Clutch ?
I am putting a Ford Motor Sports 392W into a Backdraft racing Cobra. It has 430HP with 450 Torque. Which Bell Housing/ Scatter Shield/ Clutch should I use and which ones should I definetly not use. I heard that scatter shields are great for safety but reduce ground clearance. If I go with a better clutch is there a less likely chance of a failure, thus reducing the need for a scatter shield. Are there any down sides of upgrading the clutch, like increased pedal pressure?
Cobrak |
Which transmission are you planning on using?
I'm thinking I would be using either the Lakewood, or Ford Racing/Mcleod scattershield with the clutch that close to my knees with that kind of horsepower.- Bob |
I am going to use a TKO 500.
CobraK |
| All times are GMT -7. The time now is 04:08 PM. |
