-   Transmission Talk (http://www.clubcobra.com/forums/transmission-talk/)
-   -   Tremec TKO Problem ? (http://www.clubcobra.com/forums/transmission-talk/65498-tremec-tko-problem.html)
FUNFER2 06-19-2005 07:11 PM
I have a problem with my Tremec TKO. Just currious to post this question, before I remove it from my cobra which is a pain in the @ss. The only gears that work are 1st, 3rd & fifth. Can't even get it into reverse. I did not feel any problems before it happened or hear any bad sounds. I was driving it on the highway, got onto town at the first stop light, tried to downshift to no avail. Turned around & went home. I'll have to have a friend check into it for me this week. I was involved in a wreck with the sprint car Sat. night. I tore two rotator cups in my shoulder, sliped #6 disk and ruptured #7 dick in my neck so, I can't work on the cobra myself. Anyway, any ideas on what happened ? Shift rod binding ect...
We'll find out what happened but, just currious what you guys think.
Thanks,
Kev
CoupedUp 06-19-2005 08:40 PM
You ruptured a #7 WHAT???!!!!
FUNFER2 06-19-2005 09:19 PM
It's the disk between vertebra.
thorconstr 06-20-2005 03:19 AM
Remove the tunnel and take off the covers on top of the tranny, this will give you a good idea of whats happened without pulling it. I wasn't aware that we had a #7 dick in our neck either!
richfergus 06-20-2005 04:00 AM
Ruptured a #7 dick in your neck. I do believe that's a felony in these parts. How is the other guy doing?
coosawjack 06-20-2005 04:02 AM
Adjust your clutch first.....If not disengaging completely you will have shifting problems!!!:CRY:
I have had a bunch of cable problems and know the symtoms well.:(
Give it a try.....Much easier than R & R tranny!!**)
Coosawjack:)
TedMiller 06-20-2005 05:05 AM
Kev,
Check the 2 shifter bolts, they might be loose. ??? I think more shift related, since none of the gears on the rear side of the shift patten are inop.
Ted.
NROTOXIN 06-20-2005 06:27 AM
If you have an after market shifter (Pro 5.0) the rear shift limit bolt may have loosened up. Remove the shift boot and check it out.
curtis
FUNFER2 06-20-2005 11:36 AM
yes, #7 DISK ! and did it all by myself.
I'll have him check the bolts & adjustment first.
Thanks
FUNFER2 07-02-2005 03:32 PM
Ya know, sometimes in life, we actually make things harder for ourselves, as I did about the tranny. All it was....... one bolt fell out of the trans. crossmember, just tilting it a enough so the shifter handle would hit the back of opening in the tunnel. Ba-deep Ba-deep.....that's all folks !!!
Thanks for all the ideas guys.
Kev
Dwight 07-02-2005 07:00 PM
TKO
When my TKO would not shift into reverse, 2 nd and 4 th I found a piece of rubber and carpet between the shifter and the stop. Remove them and adjuster the stop a small amount. No more problem.
Dwight
FUNFER2 07-02-2005 09:09 PM
I thought I....was an idiot ! hehe! just kidding Dwight. I'm happy it was a easy fix fer ya.
Kev
