-   Transmission Talk (http://www.clubcobra.com/forums/transmission-talk/)
-   -   Toploader code (http://www.clubcobra.com/forums/transmission-talk/77964-toploader-code.html)
double ugly 04-07-2007 04:25 PM
Toploader code
Can anyone tell from this code which toploader we're looking at? Close ratio verses wide.
The number on side is C4AR-7006-A There's a number below it that starts with a W-2C"8?"5 "7?"
Thanks, John
Anthony 04-07-2007 04:50 PM
Gear ratio is determined by tooth count on second gear.
If it has 28 teeth, it’s a close ratio. If it has 31 teeth, it’s a wide ratio.
tmareina 04-07-2007 05:39 PM
David Key has all the numbers and ratios along with the origonal type vehicle the transmitions came from on his web site.
Check it out.
Tom
Ibr8k4vetts 04-07-2007 06:31 PM
There should be a metal tag on the side of the tranny with letters and numbers. if not you have to do a tooth count on second gear.
Anthony 04-07-2007 07:25 PM
If the tranny has ever been rebuilt, then there is a chance the gears may have been swapped
