Old 09-13-2008, 11:35 AM
Default tko600 on stroked 351w
My engine builder continues to rmind me that I need a spacer to install a tremec tko-600. I need a bit of help understanding this. The why and part numbers. Thanks
Old 09-13-2008, 12:29 PM
jwd's Avatar
jwd jwd is offline
I guess it depends on which model of TKO you get. I'm using a Ford Motorsports safety bellhousing (M-6372C) and TKO 600 (M-7003-R58C). No spacer needed.
Old 09-13-2008, 12:52 PM
ekrupa2's Avatar
351W stroker with a Quicktime bellhousing and a TKO 600. No spacer was needed.
Old 09-13-2008, 01:21 PM
Cobra Make, Engine: jbl
fms aluminum bellhousing and tko600, no plate.
Old 09-13-2008, 02:33 PM
Default cont
Thanks for the help. Any recommendation on clutch?
Old 09-13-2008, 09:25 PM
flyboy1997's Avatar
Send a message via Yahoo to flyboy1997
Same combo as You with a Lakewood BlowProof & a spacer, I let the TKO guys send me the correct spacer.
Old 09-14-2008, 08:48 PM
Cobra Make, Engine: BDR 187 Prism Red w/Silver stripes; 427 stroker by Smeding Performance, Tremec TKO600 gearbox
I have a SB stroker with a TKO600. Read my post in this thread for what I put between them. (No spacer was needed, btw.)
Just Received #390
'round Midnight
You'll feel me coming
A new vibration
From afar you'll see me
I'm a sensation!
-Pete Townshend, Tommy
Old 09-15-2008, 04:32 AM
Guys, you can also use a Quicktime bellhousing. They don't require a short input shaft or a spacer. They also are SFI approved and only weigh 20lbs. I'm a distributor, let me know if you have any questions.
Old 09-15-2008, 06:48 AM
aluminum block is in
about the end of 1st page and start of second are two clutch choices, if i was to do it again i would go with mac vbach's recommended setup. with either of these clutches you can use a lightweight aluminum bellhousing, i wouldn't recommend either of these clutch setups or bellhousing if you are doing drag strip time.
Old 10-07-2008, 05:32 PM
TXBLU's Avatar
Was your engine builder trying to sell you a transmission that he had? If that's the case, he might have a transmission for a GM application.
The input shaft on the GM spec TKOs is 6.60" inches from the front side of the main case to the end of the shaft. On the Ford applications, the shaft is 6.0" from the front of the case to the end of the shaft, thus you would need a spacer to keep the input shaft on the GM transmission from bottoming out in the crankshaft.
Just a thought...
Eric
Old 10-07-2008, 06:16 PM
ford tko600 tcet5008 7.2"
chev tko600 tcet5009 6.7"
is what i have written down, could be wrong.
Old 10-14-2008, 10:52 AM
Default Thanks
Thanks for all your input. I'm planning on using a quicktime housing. Sounds like that is a prefered setup.
Old 10-14-2008, 11:00 AM
Hey Cal,
Shoot me an email or PM with what you need. I sell Q/T bells, along with Tremecs and I give great discounts to CC members.
