-   Transmission Talk (http://www.clubcobra.com/forums/transmission-talk/)
-   -   Leak in tail shaft. (http://www.clubcobra.com/forums/transmission-talk/92048-leak-tail-shaft.html)
mpanten 10-03-2008 05:48 PM
Leak in tail shaft.
My 3550 is leaking in the tail shaft. I replaced the seal and the yoke and It still appears to be leaking. I was told that the seal is the same as a t5 from a 1980's on mustang. Can anyon confirm this? What else could it be?:CRY:
MacGyver 10-03-2008 06:56 PM
Sounds like you took the first logical approach, replacing the yoke was a good measure. I can't answer the question of seal type but assuming it is correct I have a few Questions.
1.How many miles on the first seal?
2.How many miles on the 2nd seal?
1. Have you checked the vertical play in the yoke. In other words grab the yoke and move it up and down. Excessive play won't allow even the best correct seal to work. This would indicate a worn tail-shaft bushing/bearing.
2. How close is the yoke from bottoming into the end of the tail-shaft when the rear suspension travels. Too long of drive-line or loose rear suspension components can cause the drive-line to bottom in the trans damaging the seal and possibly more.
3. One thing I failed to take into account, Is the rear suspension independent or straight axle? This would obviously effect the factors on question 2.
To check items 2 & 3 the vehicle needs to be on a ramp hoist, a pit or the rear axle needs to be supported by jack stands to simulate proper rear suspension load and drive line position.
Good Luck, Matt
mpanten 10-03-2008 07:12 PM
Matt,
I cant feel any play in the shaft, I will check it again but I dont think there is any. . I dont know how many miles were on the first seal but there were less than 50 on the new one and the leak never went away. Does anyone happen to know what seal goes in there. The one I have seems to fit but I guess it could be wrong. The one thing I did notice is that the dust seal is to long and actually fold in on it;s self so it is actuall double thickness . I cant imagine that is it but Im about out of options.
