SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
December 2025
Old 10-28-2008, 11:54 AM
tc_sj's Avatar
Cobra Make, Engine: SPF#1751 CHP 427
Default Transmission oil / check
How do you check the transmission oil level in SPF and what kind of oil does it required
Thanks
Old 10-28-2008, 11:59 AM
Got the Bug's Avatar
Tan - If your car has a Tremec TKO, here's a link regarding the fluid.
http://www.ttcautomotive.com/English...ps_117_117.pdf
Doug
scootter's Avatar
Cobra Make, Engine: SPF #1436 514
Tan,
If you have the Tremec Trans, which I'm sure you do, there is two plugs on the passenger side of the trans. One to drain it, and one to fill it. The top one is obviously to fill and check the level.
You will hear about all kinds of different oils you can use. I use the recommended Synchromesh oil from Cheby( GM). I know you can get some different types at Goodies or even off the Performance Unlimited site.
Scott
Old 10-28-2008, 01:47 PM
tc_sj's Avatar
Thanks Guys
Tan
