Tremec electronic speedo connection
1 Attachment(s)
Can anyone point me at a source where I can buy a connector to plug into the electronic speedo plug on a Tremec TKO?
I found this picture which shows the item. I am looking for a 2-wire connector to plug into the blue receiver near the top of the photo. Thanks, |
What brand of speedometer do you have? I had a VDO and used a Hall Effect Sensor that had 3 wires coming out of it and you just spliced the leads from the speedometer to them. One ground, one hot, and the sensor lead. I don't remember seeing a unit like that in any of my books.
Ron :confused: |
Do what I did, simply go to your local Ford dealer and get the one for the T-5. I have Sport-Comp gauges and it worked like a charm. Cheaper than the one supplied with the gauges.
Roscoe |
I am using a Smiths electronic speedo. The wiring is all fine and the speedo is working but I don't have the right connector. The wires are using VERY non standard bullet connectors which are barely holding on.
I know the connector has to exist somewhere??? :confused: Paul |
Sorry Roscoe, didnt see your post before I hit submit!
I will wander to the local Ford dealership tomorrow and see what they have. I assume then that it is a 2-wire plug that hooks directly into the blue area. Paul |
Hi pcoghlan,
I stock all the connections and have a speedo plug the cover the hole on the drivers side speedo port. |
Give me your address I'll drop one in the mail
Chet cschwer @ atlanticbb.net |
Chet, thanks a million! I will PM it now...
Paul |
Hi pcoghlan,
I wish I could give parts away but keep me in mind for other parts needed. The rubber plug that covers the speedo port is not a proper plug to cover the speedo. I also make midshifters and have a reverse lite switch that has weatherpack pigtail. |
Mike, you have a link that shows different shifters you do for the Tremec?
Might be interested in switching from a race style to a 'hooked back' classic style. Paul |
Hi pcoghlan,
I'm not the web guy I should & need to be. I'm a car guy that developes parts that are needed. I can email you pictures of what I have tomorrow. Pop me an email and I'll send the pictures to you. Thanks for your interest, |
Mike
I did email you earlier re the speedo plug so you can use the address. Thanks, Paul |
| All times are GMT -7. The time now is 10:41 PM. |
