Please help adjusting float for IDA 48
Hello all,
Can someone please post the best way to adjust the float level and what should the value be? Also, By verifing the level in the main air stack can someone please tell me what the measurement should be? |
I have a pdf file that spells it out, but at 1.1mb it is too large to attach here...Any suggestions on how to post it?
Gun Doc |
Pull your main jets. The fuel should be 43-42 mm below the surface of the carb were the jets go in.
Here is the URL to the float adjustment page: http://www.piercemanifolds.com/Float_Level_2.htm
Gun Doc |
mine are 43 mm from the top cover. I guess I am within spec.
| All times are GMT -7. The time now is 07:12 PM. |
