Go Back   Club Cobra > Club Forums > Windy City Cobra Club
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 09-08-2006, 03:49 PM
jeffko's Avatar
Cobra Make, Engine: BDR #177 Carbed Ford Small Block
I have had a chance to get home and put a couple shots of jet fuel in the tank which cleared things up a bit. I do recall there may be one other reason for the irreverent coolant posing as fuel. Two problems can occur with the intake manifold. It is much more prone to warping if not torqued in the proper sequence and if you use the cork as a seal at the front and back of the intake to the block. The cork has a tendency to "hold" the intake out giving false torque readings and can also cause misalignment. Most builders will just use a big bead of high temp gasket maker instead of the cork.
I may be back if I have enough fuel to support the after burners.
Tis better to burn out than to fade away. So "Lite 'Em Up!"
Old 09-08-2006, 05:15 PM
Jerry Clayton's Avatar
Chris
If you want some thoughts on your problem we will be here tomorrow after aprox 1030am. or-----
You have a on going reacurrance of the same series of problems---you need a fresh slant on things--if you are getting that much coolant in that amount of time, if it is a crack in a head or block you should have combustion traces in your cooling system
Jerry
Old 09-08-2006, 09:23 PM
CHRIS DAMSCH's Avatar
Cobra Make, Engine: SPF 1454
Alright. I decided I would like to dive into this project of disassembling on Sunday morning. If anybody is interested in lending a hand I would be very happy to have you.
I'm still very bummed out. Go figure. Hopefully it's just a head gasket or a warped head. If it's a cracked block I will be down for the count for a long time.
Lets all hope for the best.
Let me know who plans on stopping by. I will start at 8:00am on Sunday. Bears are on at 3:00 I believe.
Thanks
CHRIS
Old 09-08-2006, 10:20 PM
Cobra Make, Engine: FFR 5013 - Warmed up & enlarged 302, carb- Painted RED
I'll be there. Probably R.Musson too, I talked to him tonite & he has Sunday free.
Get gaskets tomorrow!! I looked up the ones I used & they did not have the little "speed groove" in the coolant passage area, hopefully you can find some that don't have that. I think the # was Fel-pro # 1250
Michael
It's not the size of the dog in the fight, it's the size of the fight in the dog!
Old 09-09-2006, 06:07 AM
jeffko's Avatar
I wish I could make it Chris, but I simply can not. Let me know if it turns into a Monday evening though. If you replace a head gasket don't forget to paint it with silver oxide or mr gasket copper. Good luck.
Old 09-09-2006, 06:17 AM
Barn$nake's Avatar
Club Cobra Member
Cobra Make, Engine: Shell Valley 351 Cleveland
Chris,
Between you and Rich and MD you have
good people on the problem. I had the right side
head off my 351 C last year. Not a bad job
it is just the worry about scratching something. I'm sure you
guys know already ( only a reminder) to pull the block plugs. As long as you are looking for coolant tracks that will keep everything
nice and dry when you pull the head. My fingers are crossed.
Hope the BLUE car is roaring by kickoff time.
Are you still at the house that you had the campfire at?
Ed Paz
Old 09-09-2006, 06:03 AM
Chris,
I can help and I'll drop by your place at 8:00AM Sunday.
Badman
If you can't drink it, eat it, "kiss" it, spend it, or drive it fast...get rid of it!!!!
Old 09-09-2006, 06:54 AM
Club Cobra Member
Cobra Make, Engine: SPF #1507 427 Dart Block Windsor
Chris,
Sounds like you have 8 hands on the job already, plus your dad for comic relief. I should be able to get out there if you need me and will be happy to help if you want. Even if you don't want, it looks like a good excuse to hop in the Cobra if it's a nice day and I do have to run an errand in Schaumburg and maybe one in Wheeling if time permits.
Do you need any tools or other stuff? Do you have compressed air?
Lowell
Old 09-09-2006, 08:26 PM
Thanks guys. We'll see you in the morning.
Lowell, No compressed air. Come on by.
Mike, Those are the gaskets that Mroz said he used also.
I just got home from working at the house (I'll have to pick up gaskets in the morning).
And finally, I am still at the same house as the campfire. And yes, it's still for sale for anybody interested...
See you all in the morning. I'll be the valet in the morning..........
CHRIS
Old 09-10-2006, 05:13 PM
RedSnake351's Avatar
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
SO, what's the verdict?
Don't just leave us hanging. Did you have to re-mortgage the new house also?
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
Old 09-10-2006, 05:32 PM
See you all in the spring..............................
Quicker than ever hopefully.
Cracked block in the #4 cylinder.
Thanks to all that participated in the surgery. I'm taking shortblock donations....
At least I can spend some time detailing my engineless bay.
Over and out
Chris "the new fender waxer"
CHRIS
Old 09-10-2006, 05:38 PM
Thumbs down That's NOT Good News!
Damn! Double Damn!!
Very sorry to hear the bad news, Chris.
Ralph
Burma Shave
Old 09-10-2006, 05:50 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Chris,
When you get the engine out, I have a nice pattern for a heat shield for the brake lines on the drivers side upper frame. A snap to fab and install with the engine out....
Old 09-10-2006, 06:57 PM
Barn$nake's Avatar
Club Cobra Member
Sorry Chris,
If it would be any help, I have a 351 Wheezer shortblock in
my garage out of a 1993 truck. You would be out the
gaskets and labor. If you do not blow it up just give it back when
you are done with it. As Rich said, you are the Great Blue Hope!
Ed Paz
Old 09-10-2006, 07:17 PM
Chris
Tell me where the cylinder is cracked--maybe you just need a sleeve installed
Jerry
Old 09-10-2006, 09:29 PM
Club Cobra Member
Chris,
Some good suggestions here. With a little thrashing you could be back on the road in a day. If next Saturday is nice, I'll be up at Elkhart Lake and the other guys'll probably be drag racing but if the weather's crappy, we could all get together again and drop Ed's motor in your car, slap your heads and intake on it and you'd be ready to go. If not Saturday, maybe Sunday. Meantime, you could pull the intake and heads off your motor and see just where the problem is. If you use Ed's short block and yours can be sleeved, you could still enjoy your car for the rest of the fall and reinstall your motor over the winter. Minimal down time and minimal expense. Whaddaya say?
Or...we could put Ralph's motor in your car and paint it half red...
Lowell
Old 09-11-2006, 05:41 AM
Club Cobra Member
Oh, BTW, Chris,
If you haven't already, pull the drain plug on the side of the block and drain all the water. Then turn the motor over a couple of times to push all the water out of that cylinder, squirt in some oil (wouldn't hurt to squirt some oil in all the cylinders while you're at it) and turn it over a couple of more times. It would really suck to have the rings rust in the cylinder after everything else.
Lowell
Old 09-11-2006, 06:43 AM
jeffko's Avatar
Nice offer Ed, excellent suggestions Lowell. We still have a couple months+ of driving weather. Jerry has another great suggestion with sleeving the cylinder and while you’re at it we could check the bearings and go thru the bottom end, get a set of heads you like and reassemble everything. Depending on the heads you choose I bet you could get all this done for less than $3k and have a fresh engine in for the spring. We could call it daisy or whatever the name of a blue flower is.
What do you think Chris?
Old 09-11-2006, 07:43 AM
Or you could sleeve it and race it Saturday
If you let me know I'll plan Wed to put in a sleeve, I just need to know the bore size and what block it is ( ford, dart,etc)
Jerry
Old 09-11-2006, 10:59 PM
Originally Posted by Jerry Clayton
Or you could sleeve it and race it Saturday...
Jerry
Hey Jerry, you promised you'd have my Kanuten valve in by this weekend and now you're offering Chris's "Blew" motor to be ready by Saturday?
I can see what color Cobras you prefer!
Crash
Burma Shave
Display Modes
