Go Back   Club Cobra > Dwight
Conversation Between Dwight and R&B back
Showing Visitor Messages 1 to 3 of 3
  1. R&B back
    06-08-2020 12:05 PM - permalink
    R&B back
    Thank you. My tunnel has some structural issues which I will now fix while doing the interior.
  2. Dwight
    06-05-2020 05:56 PM - permalink
    Dwight
    I installed a 3550 which is the same size as the TKO 600. You will not need to modify anything but the cross member which is easy to do.
  3. R&B back
    06-04-2020 07:57 PM - permalink
    R&B back
    Hi Dwight,
    I did not want to highjack Hank's thread with a 66 Fairlane question. But may I ask are you putting the TKO 600 in the 66 Fairlane? I purchased a 66 Fairlane in 1985 but later pulled the engine and transmission to put in the Cobra in 2000. Why? Because when I went to rebuild the engine in the late 90s it turned out to be a non-original 428. I am finally starting to restore the Fairlane with an 390 TE and I think TKO 600. Do you know if the Fairlane tunnel has to be modified for the 600 to fit? Thanks.
