Go Back   Club Cobra > JKleiner
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Conversation Between JKleiner and Gofastoldguy
Showing Visitor Messages 1 to 1 of 1
  1. Gofastoldguy
    01-15-2013 04:03 PM - permalink
    Gofastoldguy
    JKleiner...I need help with my front suspension. I had taken your advice and purchased 5" steel sleeves for my FFR front suspension (MKII,2002). When at my alignment shop substituting the sleeves we encountered a problem. We were unable to adjust the caster and camber out of the positive ++ range on the machine. I have a feeling we did something wrong in the substitution. 1) do we need to replace all the forward and rear sleeves? Meaning do we need qty 4 sleeves? We put the 5" sleeves on the rear facing adjusters. Is this correct if we are using only 2 replacements? Should I buy another two sleeves and replace the front adjustment arm sleeves also? All our readings at this point are +2-3 degrees camber and -neg caster. Help! Give me your phone number and I can call you direct. Thx
    Bill Bryan 623/935-0865
