Go Back   Club Cobra > Horseracejudge
Conversation Between Horseracejudge and Roylerumble
Showing Visitor Messages 1 to 1 of 1
  1. Roylerumble
    04-01-2021 04:30 PM - permalink
    Roylerumble
    I saw your post from way back on fitting a EFI 5.0 in a CR kit. I'm in the planning stage and researching where I might run in to troubles, and helping build another one from the ground up. The builder has spent a ton on cutting out the front crossmember and replacing it with a newer style front end, 4 bar rear suspension system on a 9" rear, 5.0 as well. I'm hoping to be able to use some convertible mounts, a road race pan, and some kind of a gt40 intake because I hear they have a lower deck height. I was hoping to pick your brain about a few more details on your install. What intake is that? It seems to have a longer neck and a bend before the throttle body. I've been searching the internet for a similar one and cant find it. What other components did you have to add or change? What did you do for a belt system and fan? I bought a never assembled kit and a 91 lx 5.0 fox for the driveline. Thanks in advance for any advice.
