Go Back   Club Cobra > Haas_guy
Conversation Between Haas_guy and 40k Later
Showing Visitor Messages 1 to 6 of 6
  1. 40k Later
    04-30-2018 12:19 AM - permalink
    40k Later
    Do you have a part number for the shock. You accomplished what I envisioned. It looks great. How wide are you thinking for a rear tire?
  2. 40k Later
    04-30-2018 12:15 AM - permalink
    40k Later
    Thanks, I too think 150lb is a good starting point.
  3. Haas_guy
    04-28-2018 07:23 PM - permalink
    Haas_guy
    Qa1 shocks, I started with 150lb springs. That may change later, but I figured it was a good starting point. 18 position adjustable compression/rebound
  4. Haas_guy
    04-28-2018 07:21 PM - permalink
    Haas_guy
    I added some pics, let me know if there is anything specific you would like to see.
  5. Haas_guy
    04-22-2018 04:37 AM - permalink
    Haas_guy
    Marty,
    I can get some pictures and post them.
    Jeff
  6. 40k Later
    04-02-2018 09:12 PM - permalink
    40k Later
    You mentioned changing your rear shock set up to coil overs mounted inside of the frame rails. Do you have a picture and What shocks/spring rate did you use? If you don't mind I'd like to maybe copy some of your handy work?
    Thanks
    Marty
