Old 11-10-2009, 05:06 PM
Dwight's Avatar
Dwight Dwight is offline
Smile rock gaurd
No change in cooling. And I drive in 95 degree weather here in Alabama.
I think I bought a 24" x 24" piece but cut it down a little. Take a piece of cardboard and cut it to fit. Don't make it to big or you will not be able to put it in from the front. Remember that you only need to cover the part of the radiator that you can see as you squat down and look at the car. You should be able to mount it with stainless bolts, washer and tubing. Use the tubing for stand offs. Worst case you may have to get someone to weld mounting tabs on it.
Dwight
