Old 11-11-2009, 03:10 PM
400TT's Avatar
400TT 400TT is offline
Originally Posted by albanycobra View Post
Hi Paul
What it means is as the brake pads wear out the caliper pistons move further out. The problem is that there is nothing to protect the piston from dirt / corrosion / damage so when you put new pads in and push the pistons back the seal may get damaged or crap may just get under the seal and cause a failure.
When changing pads on any caliper without external dust seals you must use a brake cleaner to clear the exposed surfaces before retracting the pistons. This is part of the standard service technique for Wilwood etc. The pistons on these type of calipers are usually stainless and the seals are also of a higher quality as they only run a single seal.
There are production vehicles without dust seals on the calipers.
I expect Wilwood state they are not for road use purely for litigation reasons.
RCR have not yet committed to any particular caliper brand in Australia. We have been investigating and testing a variety of brands to come up with the best solution for Australian road/track conditons.
www.absolutepace.com
