Old 11-12-2009, 06:37 PM
blykins blykins is offline
Let me give you some advice.
Don't listen to anyone on a tech support line.
Take advice from engine builders that use the parts, build the engines, and put them on dynos.
You can call Comp Cams and ask for cam advice. Then you can call back, get another guy on the line, and they'll recommend something totally different. Most of these guys are bench racers and are paid to answer the phones and look in books.
Rodknock, you're absolutely right....AFR, Brodix, Trick Flow....they're all really good heads and are what most builders prefer to use to make big power.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
