Old 11-15-2009, 01:49 PM
Hray Hray is offline
Cobra Make, Engine: classic roadesters ltd, 302, T5
trying to get some quality time in with the car.
Questions: I notice the previous owner drilled and installed some quarter inch bolts in the fire wall, as well as mounted the relay bracket inside the firewall. Problem is that the screw heads are on the outside of the firewall.
Delima: I want to have the firewall as clean as possible, eliminating as many bolts and screws on the firewall as possible. What have some of you done to make the firewall as clean a possible.
History: I have glassed in oak slats on other glass cars on the inside, I then use wood screws to attach brackets to hold stuff. I have also welded in brackets and plates to use to mount stuff. As I do this on the cobra what do I need to do to not mount something in the wrong place and then have to redo it.
Thanks. Ray
