Old 11-15-2009, 06:09 PM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Okay, this is the PAY IT FORWARD list 11-15-2009 @ 9:05 pm EST.
If you are just tuning in, here are the guidelines.
1. You're offering the item for free.
2. Recipient should be willing to pay for shipping, but the offering party can volunteer to cover that if they choose.
3. Recipient pledges to "Pay it forward" at some point in the future with another item for another Cobra enthusiast.
4. Don't abuse the privilege. It's an honor system.
5. Services may also be offered up...indicate City, State.
Here are the items being offered - free basically.
1. Superformance front marker lenses, clear/white type (Lucas with fluted lense and chrome trim ring); 2 pairs available (see Dean or Rodney)
2. 2 Piece Rear Seal kit for a 351 Windsor; 2 kits available (see Blas).
4. I have both a 19 and 17 tooth driven speedo gear for a Tremec T600. Let me know if anyone needs them. I will cover postage (see DCDoug).
5. 2 round red tail light lenses that are glass they say "England" and have the number 488 on them; have the 2 trim rings that go with them these are the ones that the rubber grommet holds them in place (see RustyBob)
6. FE engine (complete) in the back of the barn off my crane. (see trularin).
8. 3550 (with shifter) that has a crack in the main case that you can use for parts. Not sure what shape it is in because it was given to me. Whomever wants it pays shipping from Manteca Ca. 95336 - (see tcrist)
9. 99% of the complete stock heater assy "used" for a CRL C427 (see Terry).
10. set of stock ceramic coated SPF side pipes. They need some cracks welded up. (See Silverback51).
14. Steering wheel center cap (small nick) with AC logo. (See vanoochka )
16. A new Duraspark ignition module. ( See Blas )
17. I have the ROTOR, CAP, and the PLUG WIRE COVER new never used for FE? ( See rustybob )
18. 6 70s Vintage Road America Pit/Paddock passes from Road America (see Chris)
19. Cobra valve covers; Ford Motorsport. ( See springin )
21. Polished alum. air cleaner. ( See springin )
22. Numerous new anodized braided line fittings. ( See springin )
24. I have a Lincoln Mark VIII fan in excellent shape with shroud. ( See Mohuska )
25.I have several radiator shrouds w/fans, 2 are the Taurus high output ones, one I think came from a Mustang....pictures available upon request.....I will try and get pictures to post as soon as I can....also have one shroud without fan....Earl
26. I still have an early set of 260 heads available - One is an Oct '62 casting and the other is a Nov '62 casting. ( See Nope It's Fake )
27. I just found 1 FE water pump pulley (single pulley). March, billet aluminum, 6 inches in diameter. ( See David Kirkham )
28. Just found a throttle return spring bracket. Fits both FE and small block manifolds (well, the ones with the little stand cast into the manifold). ( See David Kirkham )
29. Original FE oil pump filter housing (the one that bolts onto the block). ( See David Kirkham )
30. I just found an FE distributor hold down--billet, of course. ( See David Kirkham )
31. I don't have much but I have a mallory dist with mech advance, I changed it for a vacuum advance model, maybe some one can use it. It was came from my 428 FE. ( See davecobra )
32.Available for local pick up, 2 set/pair of SPF "take off" headlights w/o bulb. ( See Randy Rosenberg )
34. I also have a slightly used heater riser elbow from Greg Donohue Restorations ( See elmariachi )
35. I have one chrome bullet style side mirror brand new in the box. ( See xlr8or )
Please look over the list and make sure things are correct.
Guys, help me here, put the item number somewhere in the post.
If it is in red, it is going or gone. If it is gone, please post it.
Please let me know if an item is GONE!
mike55, I am not sure it works that way.
Earl, good to hear your wife is recovering. Take your time.
