Thanks as always for the help my friend!
Well here's the info you asked for.
1 3/8 " input 10 spline 3/4" shouldered tip
1 3/8 " output 31 spline
tail shaft # DOZR-7AO40-A
MAIN CASE# CBAR 7006-W1
On the input shaft there's a collar with a seiral as well #WT2-96-6A .
One other question the hurst linkage seem's sloppy due to the keeper springs, it already has the steel bushings but still seems sloppy . have you ever replaced the adjuster ends of the linkage with hiem joints? I'm considering doing this to achieve a more positive adjustment and tighter feel. Good or bad Idea
thanks!
