Old 11-17-2009, 03:13 AM
Zedn's Avatar
Zedn Zedn is offline
Thanks for the reply,
I am just changing the seal as the bearings appear to be fine. I am worried about over crushing the crush sleeve.
I dont have a sensitive enough torque wrench so i will need to see if i can borrow / buy one.
When i said backlash torque, i meant the drag. I will do as you say and tighten to 25 in-lbs.
I have been doing some reading and it looks like if i do what you have said it should be fine provided i work slowly and dont over crush the sleeve.
Failure to mark was more a case of ignorance rather than rushing.
Cheers.
Liam
