Thread: carbs bog!!!
Old 11-19-2009, 09:55 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
you have listed two different sets of jets/ pv ratings--what do you have???
Disconnect the seconary carb, and see if this bog is just on the primary carb---
Are the carbs stock 427 carbs?? you listed mech---- do they use seconary metering plates instead of jets??? any pics of your setup???
On the ford dist--the advance is under the breaker plate and has 2 differnt notches for amount of advance--usually about 3 or 4 degrees differance.
