Thread: carbs bog!!!
Old 11-19-2009, 04:07 PM
Tom Kirkham Tom Kirkham is offline
CC Member / Sponsor
Originally Posted by jhv48 View Post
Wouldn't three turns out be too rich?
If you must adjust the idle screws that far rich it means the idle circuit is too lean. This could be due to a vacuum leak, a dirt in the idle circuit, a throttle blade opened too far, too big of hole drilled in the throttle butterfly, etc.
If the throttle blade is opened too far at idle you will be out of the transition slot...
Check out Innovate Motorsports web site and forum:
http://www.innovatemotorsports.com/f...isplay.php?f=7
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
