Old 11-19-2009, 07:41 PM
olddog olddog is offline
Originally Posted by fastd View Post
All,
My tuner came back to me and said he thought the 600 cfm dp would be a better fit than the 650 dp; based on David G's and olddog's post, you guys would probably agree...?
Fastd
I'm a little late, but yes. I would think the 600 would be just fine. I don't think head and cam changes are going to need more carb unless you rev much higher, which I doubt your bottom end is good for.
In my puppy days, I liked the spread bore carbs for engines that ran through a large rpm range. The smaller bores were more tunable at idle, and the big bores breathed better in the 8000+ range. I don't think you would need one.
I don't think I ever ran into a hot rodder with a small block that was't over carbed, or a big block that was under carbed. You might be the first.
