Thread: carbs bog!!!
Old 11-20-2009, 12:57 PM
Tom Kirkham Tom Kirkham is offline
CC Member / Sponsor
Originally Posted by cdnus View Post
Tom,
Perhaps when you have a little time, could you please post more info on how to alter with expected results the transition circuit.
A few photos would be greatly appreciated also, for the carb challenged.
Craig
Sorry to have taken so long to post the pic.
In this picture I have put some paper clips pointing to where the idle restriction is. Please note: that Holley only uses one or the other location as a restriction, not both. Typically there is a brass slug that has a calibrated hole. This restriction controls your idle/transition circuit. You will need a number drill set and a pin vise. Measure the diameter of the hole before you start so you can go back...
http://www.mcmaster.com/#metalworkin...d-rods/=4l7tlr
drilling the jet bigger makes the circuit richer. Go in small steps...
Please note: that I only put pointers on one side of the block. The right hand side has the same restrictions.
As a side note: I have never seen this circuit too lean from Holley...
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
