Thread: carbs bog!!!
  #29 (permalink)
Old 11-20-2009, 02:31 PM
cdnus cdnus is offline
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
Thanks Tom,
Not long at all.
I can achieve any A/F @ idle I want with the scews, but when I have it in a reasonable range 13.5-14.7 the cruise ( below 22-2300 ) will run as high as 16+. I keep tabs on the plugs & everything looks ok, pretty white but ok. As soon as I apply a little throttle it picks right up 13.5-14.5. The richer I run the idle the better the cruise is, But as you know there are limits to that.
Your mod--will it richen up & change the idle adjustments also, or will it just help out the transition?
I have 18000mi on the engine & get 22 MPG average.
Thanks again
Craig
