Old 11-20-2009, 09:12 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Blas to base...over...<click>
Don't tell anyone but my car has the Blue H4 Halogen Headlights/ (Astra H4 High-Output (90/130) headlamp bulbs) And do they cause any problems you ask?...Well Hell.......yes...But..I am..."A WILD AND CRAZY GUY"
I pop a headlight relay every other year...So I always carry 2 spares with me where ever I go...at $16 a pop...
The problem occures (I think) when you go between the highs and lows...that's when the relay usually gets toasted...The std headlight wiring is 1.5mm to the lamps...
I have a schematic of a wiring modification (somewhere) that I was planning on adapting to eliminate that nasty & expensive Audi/VW relay...to use 2 cheaper relays...(one relay for high and 1 for low beams) I'll add it to my wiring diagrams too.
If I find my example I would post it in my gallery, but it's not my document, that is, it's someone elses intelectual property... and that would not be fair without permission. Maybe get it done over the winter sometime. Too busy right now because...
On a side note:
I'm up to my ears in the dash lighting upgrade project right now...Blew my 12v power supply 2 weeks back so nothing got done. But got a new one, and lit the mock-up display dash wednesday evening. A major improvement to the std lighting, except for the tach, I'm still working on it...
over and out <click>
SPFWiringDiagrams@Comcast.net
