Old 11-22-2009, 06:57 AM
fkemmerer's Avatar
fkemmerer fkemmerer is offline
Cobra Make, Engine: ERA, FE BBF
Here's a picture of the setup that ERA did for my cobra. You can download a higher resolution version from my gallery:
We did a remote battery cutoff switch which is mounted to the lower right of the battery itself. Hope this helps you. My setup uses both the top and side terminals on the optima battery (the side terminals are used to power the EFI computer even when the battery cutoff has disconnected everything else.
- Fred
