Old 11-23-2009, 10:51 PM
Ralphy's Avatar
Ralphy Ralphy is offline
I recently purchased a pre owned EM. I have checked all the fluid levels and I am always visually going over every nut and bolt. Recently while climbing under the rear I discovered a half shaft bolt backed out about the thickness of a washer. When I checked closer I discovered all four bolts were loose. Also no lock washers were used on this same side. So I would advise every one with a purchase of these high horsepower beasts. To do extensive checks. Also avoid the heavy foot for a while and use your senses to detect unusual sounds, feel, smells, etc.....
