Old 12-11-2001, 07:20 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
4RE, It sounds like the springs are weak under load. There are 2 options you can use. The 1st would be to change the stock springs to a Blue coil. DV sells these. The 2nd option would be a coil over. I use the ProShocks coil over setup on the rear. This would give you the adjustability. The costs for the blue coils is around $125. The coil overs are about $375. You remove the old coils and run the coilovers alone. If you are interested I can tell you how to mount them with the proper spacers and bolts.
Don
