Old 11-24-2009, 12:19 PM
ou812545's Avatar
ou812545 ou812545 is offline
Cobra Make, Engine: SPF 2168, 418, TKO 600
Originally Posted by Got the Bug View Post
Dan,
Here's a thread with a picture. The front and back on the driver's side failed completely.
Mustang ranch- roush authorized dealer
I'm currently using the Edlbrock gaskets (EDL 7220), but mine is failing in a different location. Oil is leaking in the rear between the manifold and the block. Not the between the intake and the heads.
Do you know if you Mustang Ranch used cork, rubber, or a silicone bead for the rear of the manifold to the block?
Thanks,
Dan
