Thread: 557ci. Cobra
Old 11-24-2009, 12:23 PM
BAD ASP's Avatar
BAD ASP BAD ASP is offline
Cobra Make, Engine: superformance,408 w with 93mm intercooled turbo
I had a 544 cu. in. engine using the ford racing 460 block, which had the c460 heads that could only be used with a matching intake. the matching intake raised the carb about 3 inches if I remember. I have a superformance and bought a spare hood but ultimately changed my mind and went with a turbo small block instead. I think it's possible that the owner may have had the same heads causing the change to the hood.Take a look at the attachment and you can see the manifold. On top of that went a demon 1295 cfm double pumper if I remember. jm2c fwiw.
