Old 11-25-2009, 04:56 PM
Gunner's Avatar
Gunner Gunner is offline
Cobra Make, Engine: ERA 707, 446ci FE
Originally Posted by Dangerous Doug View Post
I'm thinking regulator, based on the fluctuation I see in the headlight brightness.
Unlikely. Modern VRs don't tend to "partly fail" - they either quit permitting battery charging (which is the more fail-safe option) so that the power gradually runs down, or they never stop charging the battery, which cooks it. A variation when you rev the engine etc. is more indicative of reduced battery charge, which can be caused by many things.
A loose alternator belt is one common cause. A failing battery is another. Since you do get response at revs, it's likely not the alternator itself. I'd bet on a loose belt, a bad battery, a bad connection somewhere preventing battery charging, or - very last option - a bad regulator.
= Si Opus Quadratum vis, angulos praecidere noli. =
